Pre-drilled holes too close together
When I bought my Chesapeake 18 kit, six years ago, the holes for the Keepers foot braces had been pre-drilled.  It turns out that the pre-drilled holes are 37 mm apart while the holes in the ends of the Keepers braces are 36.7 mm apart!  Has anyone else had this problem?  Is the only reasonable solution to epoxy over one of the pre-drilled holes on each side and then to drill new holes?  Is it possible that the adjustable aluminum foot braces that CLC sells might have holes 37 mm apart? Would appreciate some guidance.
1 reply:
RE: Pre-drilled holes too close together
Sorry the title should have read "Pre-drilled holes too fat apart."
 » Return to Forum Topics
