Gear | Boat Plans | Supplies | | Books/DVDs | Kayaks | |
| Forum Guidelines | Builders' Forum | |
Final sanding after paint and varnish
I am sure this question has been addressed previously, but I can't seem to find anything in my search of the forum. Do you wet sand 400 grit after the final coat of paint or varnish??? If so, how then do you make it nice and shiny? Do you buff it, and if so, with what, buffing compound? BTW, it was about 6wks ago when I said I only have 2wks left!!! Hopefully will be done soon.
1 reply:
RE: Final sanding after paint and varnish
» Submitted by Laszlo - Thu, August 28 » 4:54 PM
No, #400 will leave the surface dull. If you follow the instructions in the Shop Tips, you'll get a smooth shiny finish without sanding.
