what they said
Posted by LeeG on May 9, 2004
and stay away from the edges,,you can do some finish sanding with sandpaper wrapped around a 1" piece of minicell. Swirl marks are hard to remove so don't bear down with 80grit and the ROS.
In Response to: Sad Times - Deck Sanding by Brad Wells on May 8, 2004
24 days
for Discount Code Savings!
Ranging from $30 - $250
