Re: what they said
Posted by Brad Wells on May 9, 2004
Thanks guys. The bottom is coming along great its the sides that are the real pain with the overlapping glass and the runs. I found the weave spit test in one of the earlier posts and that has been quite useful in some spots. I may have to pickup another 6 pack this afternoon to keep my hydration level up.
As for changing sandpaper, any tips on how many minutes of sanding an 80 grit disc as good for? I use the Dewalt 5" ROS and it does a great job sucking up the epoxy dust so I really don't get much epoxy buildup in the disk like I do with the sanding block. But after sanding for 20 minutes with a disc, you can definitely feel that the grit isn't as sharp as it was at first.
I saw somewhere that someone said when they first start out with 80 grit they change the paper after 3 feet. But considering that I am going over everything real lightly at first and coming back to work work on the rougher spots, that would mean changing the paper every 2 minutes which seems like overkill.
Thoughts?
-Brad
In Response to: Re: what they said by Kurt Maurer on May 9, 2004
24 days
for Discount Code Savings!
Ranging from $30 - $250
