Re: Varnishing outside?
Posted by Chris on May 10, 2004
Um, only thing I can think of is to wet the ground inside and maybe a foot or so outside your hanging plastic which might help to keep dust from blowing around. Is your plastic long enough that you can weight the bottom edge with long peices of 2x4 or something to make the best bottom edge seal you can?
cj
In Response to: Varnishing outside? by Eugene Severens on May 10, 2004
- Ventilate! by mick on May 10, 2004
