Re: Sanding High Build Pr
Posted by Mac on May 12, 2004
Joe,
What Dick said. I'd use a fairing board at this stage - that's why you're using High Build - to fill in the low spots. Don't be afraid to sand until the high spots are exposed - it's only primer and colour doesn't matter at this stage - smoothness does. High Build is soft, so you don't want to leave on any more than necessary.
Wear a mask!
Best
In Response to: Re: Sanding High Build Pr by Dick R on May 12, 2004
