Schooner
Posted by MWagar on May 12, 2004
Dan, I have been using Interlux's Schooner varnish and am very happy with the results. I use the foam roller covers to apply the varnish across the grain. I then smooth out the bubbles with a foam brush with the grain. I have used Flagship varnish in the past, very poor results with finish quality no matter what I did. Good luck, the key to these materials is put it on fast and carefully, then LEAVE IT ALONE. If there is a problem, let it be and fix it with sanding and the next coat. I find that any fussing you do to "fix" a run or holiday, only leads to a bigger problem.
In Response to: Paint by Dan on May 11, 2004
24 days
for Discount Code Savings!
Ranging from $30 - $250
