Re: Non gloss finish
Posted by Rich on May 12, 2004
Hello fellow AH builder. I used Perfection Varnish from Interlux - a 2 part polyurethane. Just follow the instructions in the manual using grey and white scotchbrite successively. Even though I used the 2 part instead of a conventional varnish I ended up with a very nice finish. If it is still too glossy for you maybe going over it again with the grey will tone it down for you.
In Response to: Non gloss finish by Vike on May 12, 2004
