Cracked Shear Clamp
Posted by Chris F on May 13, 2004
Well, not really cracked. Failed at scarf joint is more like it. As I was stichin' up my 16Lt last night I knocked my beam spreader out (causing all sorts of chaos). When I went to jam it back in place, I noticed that one of my scarf joints was right at the beam and straining to burst. I quickly removed the spreader and had a swig of beer.
It looked like a solid scarf when I glued it to the hull panel, but it appears there was a significant void.
My solution thus far was to thicken some epoxy and cram as much in the crask as I could. With this scarf joint right at the beam am I in trouble? The panels are straining quite a bit at this point. Would I be best advised to unstitch (I'm about half way) and fix it?
Quite a discouraging event last night, as the boat was starting to actually look like a boat.
- Re: Cracked Shear Clamp by Doug Judd on May 13, 2004
Re: Cracked Shear Clamp by Mac on May 13, 2004
- Call Off the Dogs!! by Kurt Maurer on May 13, 2004
- Re: Call Off the Dogs!! by Chris F on May 13, 2004
- Re: Call Off the Dogs!! by Doug Judd on May 13, 2004
Re: Cracked Shear Clamp by Chris F on May 13, 2004
- what they said by LeeG on May 13, 2004
- Re: Cracked Shear Clamp by mick allen on May 14, 2004
