Re: epoxy fill coats
Posted by Chris on May 16, 2004
Yup, ya gotta sand off your high points. (Did that been there, gotta heavy boat). Also, do the wet test, If you can feel it, that's bad, gotta fix it. but if you can't feel it, and it disapears when you smear a drop of water, spit, or whatever, you're good to go.
Good luck, cj
In Response to: epoxy fill coats by Garagegirl on May 15, 2004
11 days
for Discount Code Savings!
Ranging from $30 - $250
