Possible solution
Posted by Baldwon on May 19, 2004
You mention: Semi-rigid air tubing . I don't know what that is. However it gives me the idea to simply run a tube through the deck and bulkhead so that the tupe makes a good seal on each entry and exit point. The rudder wire will run thought it. The question I have is what material specifically should I be using for this tube.
In Response to: Re: Rudder lines - thru d by M Davis on May 19, 2004
