Re: Pigment in the epoxy?
Posted by Don on May 19, 2004
I used Systems Three epoxy and got the pigment through them. I used white pigment on the inside and outside of the hull. It makes the inside of the hull and hatches very visible. I painted the outside of the hull white and it is great for not showing the scratches as bad. The more pigment you add to the epoxy the better the color turns out.
In Response to: Pigment in the epoxy? by Dave on May 19, 2004
- Re: Pigment in the epoxy? by Joe Lombardo on May 19, 2004
Re: Pigment in the epoxy? by Dave on May 19, 2004
- Re: Pigment in the epoxy? by Bob on May 19, 2004
- Re: Pigment in the epoxy? by Steve Miller on May 19, 2004
- Re: Pigment in the epoxy? by LeeG on May 20, 2004
- Re: Pigment in the epoxy? by Terry Mcadams on May 20, 2004
