Are all foot braces....
Posted by Doug Judd on May 19, 2004
...created equal?
What a job! I had aligned and pre-drilled the holes for my foot braces "way back when". Since my fourth, and FINAL, coat of varnish came out great last night, I decided to install the braces tonight.
One went in easy as pie. I fought with the second one for 25 minutes. Simply would not line up.
Apparently, the brace bodies must come out of different cavities and the screw hole placement varies just a little. Or at least enough to disallow lining up the screw.
I ended up elongating the hole in the hull panel slightly and finally got everything in place and tight. Now I need a shower or a drink. Maybe a shower and a drink.
21 days
for Discount Code Savings!
Ranging from $30 - $250
