Re: Revarnish deck & sili
Posted by Kurt Maurer on May 20, 2004
"I have taken a very sharp chisel and holding it almost vertically, scraped..."
This is excellent technique. You must have worked in a cabinet shop sometime in the past. For those of you new to this idea, you scrape with the flat side towards you, drawing the chisel towards you. And as Bill says, hold the handle almost vertically... which way you tilt the handle depends on which direction yields the best scraping action, but start at vertical. It's great for addressing small problem areas; use a larger scraper for larger problem areas.
Cheers, Kurt
In Response to: Re: Revarnish deck & sili by Bill on May 19, 2004
- Re: Revarnish deck & sili by Bill Cooke on May 20, 2004
- Re: Revarnish deck & sili by Bill on May 20, 2004
- Re: Revarnish deck & sili by Mac on May 20, 2004
- Re: Revarnish deck & sili by Terry Mcadams on May 20, 2004
- Re: Revarnish deck & sili by Duey on May 20, 2004
- Re: Anti-Bond by Dave Houser on May 20, 2004
- Scraping by Kurt Maurer on May 20, 2004
