Re: Pigment in the epoxy?
Posted by Terry Mcadams on May 20, 2004
I wonder how much a white of other light color pigment would retard UV damage to epoxy as compared to a darker or black pigment. Don't know the answer but, by analogy, I suspect the difference could be significant: I learned years ago that black or dark running rigging on sailboats holds up to UV better than white.
Of course, all you sunbelt paddlers better wear some heat insulation it you intend to sit in the bottom on a boat wih a black interior. Should make for a nice sizzle.
terry
In Response to: Re: Pigment in the epoxy? by LeeG on May 20, 2004
- Re: Pigment in the epoxy? by Dave on May 21, 2004
- Re: Pigment in the epoxy? by RogerJ on May 22, 2004
