Re: Seams on the tape
Posted by Dave on May 20, 2004
For the cargo compartments I just sliced the selvedge off with scissors and then had to be a little more careful while putting down the epoxy to keep strands from flying everywhere.
I thik I may try to slice the long bubbles out and then epoxy in a new strip of tape over the problem areas. I know this will add weight, but those gaps under the main sheet of cloth are troubling.
Maybe I could drill a few holes in the glass and inject expoxy into the gaps. Sounds like a huge pain, but it might work?
Haven't made up my mind. I may just use white pigmented expoxy and cover the suckers up.
Dave
In Response to: Re: Seams on the tape by LeeG on May 20, 2004
