Re: underneath the coamin
Posted by Tim Chase on May 21, 2004
One trick that works for sanding one area while not sanding the adjacent areas is to put a couple layers of masking tape over the areas that you don't want to scratch. Replace the tape as needed as you go along.
In Response to: Re: underneath the coamin by LeeG on May 21, 2004
- Re: underneath the coamin by LeeG on May 21, 2004
