Re: 2nd layer sanding qus
Posted by Terry Mcadams on May 24, 2004
Assuming you did not sand into the fiberglass cloth (it has a pronounced print pattern and will make your skin itch if you did), fine sand with 220 grit and apply varnish. The boat will be even lovelier than when it was just unsanded epoxy.
terry
In Response to: 2nd layer sanding qustion by Mischa on May 24, 2004
- Re: 2nd layer sanding qus by Bill Cooke on May 24, 2004
