Re: fitting bulkheads
Posted by RogerJ on May 25, 2004
Wade, although I am building from plans (not CLC's). One of the things CLC prides themselves on is the accuracy of thier computer cut parts. The bulkheads SHOULD be cut correctly. Try losening some wires and retrying the bulkheads as George suggested. The problem with trimming is getting everything symetrical again. If you take too much off one side by trimming it ain't a CLC error. And you could end up with an outtawhack kayak. RogerJ
In Response to: Re: fitting bulkheads by Chip Veres on May 24, 2004
- Re: fitting bulkheads by Dick R on May 25, 2004
Re: fitting bulkheads by George on May 25, 2004
- Rear bulkhead location by Dave Houser on May 26, 2004
