Re: Butt Joins
Posted by Chip Veres on May 25, 2004
Here's a way I (first-timer) made decent scarfs in 4mm ply: 1. Gather up all the pieces of a given width. (typically 4) 2. Cut 2 scrap pieces the same width but only about 2 inches long. 3. Mark all pieces 1-1/4 inch from the end. 4. Brad one of the scraps to the end of the workbench. 5. Stack and brad each real piece atop it forming stairsteps. 6. Brad the other scrap atop the stack. 7. Put a piece of extra-coarse sandpaper on a block. 8. Sand at the angle of the stairsteps until the cut reaches the marked line on the top scrap. Most errors will be in the scraps, with good layers scarfed near-perfect.
Chip V.
In Response to: Butt Joins by David Wallace on May 25, 2004
- Re: Butt Joins by Mike Morse on May 25, 2004
Re: Butt Joins by Rand on May 25, 2004
- Re: Butt Joins by David Wallace on May 26, 2004
- Re: Butt Joins by LeeG on May 26, 2004
- Re: Butt Joins by mike on Jun 19, 2004
