Re: grab handles and rudd
Posted by Ron Miller on May 25, 2004
I built a rudder block out of a chunk of mahogany. I drilled two holes near the bottom outer edges BEFORE epoxying it to the kyak. I intend to run a line through these holes to which I will attatch a grab handle. The line will be long enough to clear the tip of the rudder and held tight to the deck with a bungy that will be part of my perimeter deck line. That was my solution, so far so good. Will be ready to try it out in about two weeks.
In Response to: grab handles and rudder by Wayne VanTassel on May 25, 2004
- Re: grab handles and rudd by Tim Chase on May 30, 2004
