Re: 80-grit sanding
Posted by Peter Lyons on May 25, 2004
Yep... I'm with Mac. The weave will disappear (I know this from my own boat) but you sure don't want to press your luck and sand through the glass. Add a thin fill coat with a squeegee and then do a fine sanding to see what you've got.
In Response to: Re: 80-grit sanding by Mac on May 25, 2004
- Re: 80-grit sanding by Charlie Walsh on May 26, 2004
- Re: 80-grit sanding by Kurt Maurer on May 26, 2004
Re: 80-grit sanding by Mac on May 26, 2004
- Re: 80-grit sanding by Steve Miller on May 26, 2004
- Re: 80-grit sanding by RogerJ on May 26, 2004
- Re: 80-grit sanding by Mark Camp on May 26, 2004
Re: 80-grit sanding by Joe Lombardo on May 26, 2004
- True Confessions by Kurt Maurer on May 26, 2004
- Re: Fairing Board by Dave Houser on May 26, 2004
- embarrassed to ask by Joe Lombardo on May 26, 2004
- Re: True Confessions by Peter Lyons on May 26, 2004
- Go PETER!! by Kurt Maurer on May 26, 2004
