Re: 80-grit sanding
Posted by RogerJ on May 26, 2004
Yeah Charlie , LOTS of opions here. I use a home made fairing board that uses 24" X 3" belts cut at the makers join. Also use a ROS, and a Mouse, and when none of those will quite do the job sand paper held in my hot "little" hands. RogerJ
In Response to: Re: 80-grit sanding by Kurt Maurer on May 26, 2004
