Re: 80-grit sanding
Posted by RogerJ on May 26, 2004
Wow, OK this is bigger and fancier than the one I made. I use cut down belt sander belts because they seem to cut better and longer than the regular h'ware store sand paper. I also use an abrasive "cleaner" on my sand paper to clean the build up off. It looks like a large gum rubber eraser, bigger than two sticks of butter joined end to end. You can touch it to a moveing ROS, scrape a fairing board or block and it removes most build up. No it does not remove the epoxy you sanded while it was soft. RogerJ
In Response to: Re: 80-grit sanding by Joe Lombardo on May 26, 2004
