Need advice- cracked hull
Posted by Dan F on May 28, 2004
Hello fellow builders,
After two years of paddling my beautiful Ches. LT17, it has suffered a tragedy: contractors dropped a long piece of PVC pipe headlong from the roof of my house onto my boat's hull (she was stored overturned).
Now there is a slanted circular dent in the bottom panel aft of the cockpit, about 3" diameter; about 1/5 of the perimeter cracked through to the interior. The adjacent side panel has a linear, longitudinal crack about 4" long. Nothing you can see through, but clearly no longer watertight.
I'm hoping for some opinions on (1) whether this damage is repairable, and if so, (2) what's the best way?
Despondently,
Dan F.
P.S. The contractors didn't even tell me this had happened... I discovered the damage yesterday just before paddling off into the 45 degree waters of Casco Bay... would have been an unfortunate way to drown.
- no problem, always repair by LeeG on May 28, 2004
- oops by LeeG on May 28, 2004
- Re: Need advice- cracked by Petewp on May 28, 2004
- Re: Need advice- cracked by LeeG on May 28, 2004
- Re: Need advice- cracked by Mac on May 28, 2004
- Re: Need advice- cracked by Dan F on May 28, 2004
- seeing by LeeG on May 28, 2004
- Re: Need advice- cracked by LeeL on May 28, 2004
- Re: Need advice- cracked by Chip Veres on May 28, 2004
- by on
