Re: forward deck beam
Posted by FrankP on Jun 2, 2004
The deck beam, as far as I know, should have the same radius as the deck. If I remember right, the radius of the CH18 is something like 16" which will seem very flat for a distance as short as the front deck beam. If you're still worried, just match the forward deck beam against another section of deck beam. The two should match. Don't use a section of rear deck beam, though as that has a different radius.
FrankP
In Response to: forward deck beam by Kemp on May 31, 2004
