Re: Rolling with Eyeglass
Posted by Ben Fuller on Jun 6, 2004
The kind of eyeglass strap I have used for years does the job real well. It has little rubber bands that slide over the earpieces with a chinch that sets them up real tight and a slider that allows you to fasten the strap tightly to your head. If your earpieces are slippery, you can take the slider down to the hinge. I use metal frames that have plastic pieces that go over the ears and there is a real good spot ahead of it for the strap.
Most of the other ones that I have seen are junk. Fashionable yes. But if you can get the glasses off your head with out loosening the strap they WILL come off in the water.
In Response to: Re: Rolling with Eyeglass by Tom C. on Jun 6, 2004
