Tip for keeping head down
Posted by mike noeske on Jun 9, 2004
A guy in the canoe/kayak club that I am a member of gives this tip to get your head on to your right shoulder when rolling up. He says to hold the loose end of your PFD's right shoulder strap in your teeth through out the entire roll. When you come up your head will be close to your shoulder and last out of the water. Tried it and it works, just use it to get muscle memory of where you head should be, then forget it. Unless you want to add another step to your set up.
Mike
In Response to: shaking my head by LeeG on Jun 9, 2004
