Re: Center of Gravity
Posted by LeeG on Jun 17, 2004
Actually that's how to move a big double a distance. But it takes four people. Only two people in the middle doesn't work well. What can be done to make the job better is get a 12' or so length of 2" webbing or double up a cam strap then put the loop over your shoulders and the other end around the toggle with your hand holding it in place. It's not perfect but it can help if you need a hand free to swat flies!
In Response to: Center of Gravity by Mac on Jun 17, 2004
