Re: Wherry fillet tip
Posted by David Hopkinson on Jun 18, 2004
Thanks! I hadn't thought about reducing the height of the tank tops. Will check this out tonight.
I did the seats/thwarts using a very similar method to your marking with a pen. Worked well. I also considdered starting at the Bow, but opted to folow the instructions and started stiching at the stern. I did have to do a fair amount of work to clean up the Bow but it wasn't too bad.
What oars/sculls do you use? I'm looking at these options now. I will be using a Row Wing.
Have a great row in the Keys!
In Response to: Re: Wherry fillet tip by Patrick Gillon on Jun 18, 2004
12 days
for Discount Code Savings!
Ranging from $30 - $250
