Re: Primer & Paint Questi
Posted by Steve Miller on Jun 22, 2004
Another hint for tipping. Don't use a brush. Foam brushes are rotten for it. Use a second round end white foam roller. Do not put any paint on it. Run the bare roller over your surface using just the weight of the roller. As light a pressure on it as you can and still have it roll. Works much better than the brush. Also note that the foam seems to have a grain to it so try it both ways - handle on left/handle on right sort of thing.
Still waiting for a picture.
In Response to: Re: Primer & Paint Questi by LeeG on Jun 21, 2004
- Re: Primer & Paint Questi by Brad Wells on Jun 24, 2004
