Re: General S&G Tip
Posted by Mark Camp on Jun 23, 2004
If you want to really become one with the wood, use your teeth for all rip cuts.
But I will have to try your angle iron idea next time. I am not always that mushy about the handtool idea.
I don't have any aluminum, but I saved some steel angle iron from a discarded sofa bed, so I will give it a try.
One thing I did learn from watching a pro carpenter: to make some quick rip cuts in plywood with the circular saw, just throw the plywood on the lawn and cut away! Seems simple, but I can't tell you how many times I put off doing something because the workbench was too cluttered to do some rip-sawing.
In Response to: Re: General S&G Tip by Terry Mcadams on Jun 17, 2004
