Re: General S&G Tip
Posted by Kurt Maurer on Jul 1, 2004
Yes, that was amazing, Archie! Good SHOW!!!
Now, if you're ever gonna do that trick again, might try soaking the wood before steaming it, maybe for a couple days, even. Might not need the notches then (even though they WERE an excellent idea!). I second Joe's applause: and PICTURES too!
Another alternative I thought about is buying basswood sheet at the hobby shop. R/C airplane modelers live and die by that stuff, and it ought to be a dandy material for laminating end pieces. Should be easy to strip using a straightedge and utility knife with a fresh blade in it. (How many of y'all have a ten-year-old blade in your box cutter???)
Cheers, Kurt
In Response to: Re: General S&G Tip by Joe Lombardo on Jun 30, 2004
- if you want pine strips by Charlie Jones on Jul 1, 2004
