Re: Hull strenght
Posted by Dick R on Sep 19, 2004
My Chesapeake-16 has come through all the self-recoveries, assisted recoveries, and crashing surf just fine. The hull is fiberglassed, the deck not. In one exercise, a big fellow stood on the decks of our rafted kayaks. If you sealed the wood inside and out with epoxy, you should have no problem with water damage. These boats are intended to get wet, inside as well as out.
In Response to: Hull strenght by Christian on Sep 18, 2004
