Re: ch 17 - putting it of
Posted by craig on Oct 6, 2004
Buy some luan and build the boat up to the filet stage. If it looks good to you, cut the wires and trace it. Then use it as a guide whenever you get stuck. After it starts to look like a boat, and you get used to the whole thing being held together with 3 inch pieces of wire, its all downstream.
In Response to: Re: ch 17 - putting it of by Kurt Maurer on Oct 6, 2004
