Re: Ches 16 vs. Ches 17.
Posted by Craig R on Oct 8, 2004
I have just finished my 17 and I relied heavily on the New Kayak Book which uses the 16 as an example. The only differnce in construction that I can see is an extra scarf to get the length in the panels. I weigh 210lb and I wouldn't want a boat any bigger than the 17. When you say the 18, are you referring to the wr18? If so, then that boat is a multi-chine so construction will be different (basic processes will be the same though) Cheers
In Response to: Ches 16 vs. Ches 17. by Jim Whall on Oct 7, 2004
- Re: Ches 16 vs. Ches 17. by Myron on Oct 8, 2004
- Re: Ches 16 vs. Ches 17. by Paul on Oct 8, 2004
Re: Ches 16 vs. Ches 17. by Jim Whall on Oct 8, 2004
- Re: Ches 16 vs. Ches 17. by Ety Bahar on Oct 8, 2004
