Re: epoxy doesn't dry
Posted by Pete on Jul 7, 2005
thanks alot. unfortunatley the epoxy is still gummy and again i suspect the pumps ddelivered improper ratios' of hardener to resin. so i'll try to scrape it off with vinegar if you guys give the all clear...
In Response to: Re: epoxy doesn't dry by Chris on Jul 7, 2005
