If parts have cured, and
Posted by CharlieJones on Jul 7, 2005
parts haven't, then it isn't the pumps. Sorry, but that's the mixing.
If that's what has happened, you didn't mix it well enough- only way part can cure and part not from the same batch.
Been using epoxy to build boats since 1976 and that's the ONLY way I ever had a partial failure like that.
Scrape the goo out, wash the area down with whatever- I use lacquer thinner- then put new epoxy on it.
In Response to: Re: epoxy doesn't dry by Pete on Jul 7, 2005
