Re: Ch 17 LT Bulkheads
Posted by Bill Brennan on Aug 18, 2005
Lee, if I understand you correclty the reduction in max. beam from 23 1/2" to 23" is less of a worry than having the aft bulkhead so far back from its proper place. I can certainly live with the slight redcution in beam if it really does not make any difference. The bulkhead deoes fit in its proper place with the narrower beam. Everything else look fine.
Thanks again.
Bill B.
In Response to: Re: Ch 17 LT Bulkheads by LeeG on Aug 18, 2005
- Re: Ch 17 LT Bulkheads by LeeG on Aug 18, 2005
- Re: Ch 17 LT Bulkheads by Howard on Aug 18, 2005
