Re: Glassing and finishin
Posted by Kurt Maurer on Sep 14, 2005
Tim, y' got two options:
1. Live with it.
2. Sand off the cloth, apply a patch, feather it in.
Option two can be tricky. While you want to sand off all the offended cloth, you do not want to sand off the epoxy under it; if you take it down to bare wood, you'll probably get an uneven color (splotch) situation. So use a delicate touch and fine grits on the ol' ROS, or hand sand, and in either case, gggooo ssslllooowww.
Cheers, Kurt
In Response to: Glassing and finishing by Tim Cummings on Sep 14, 2005
- Re: Glassing and finishin by Tim Cummings on Sep 14, 2005
