Tabs on precut hull panel
Posted by Scott S on Sep 15, 2005
Hey All,
I've just started assembling the hull panels for a CH16. I'm using pre-cut panels from the kit. Just adjacent to the scarf joint there are tabs that protrude about 1/4" from the edge of the panel on either side. Should these be removed prior to joining the panels?
Thanks much, Scott
