Re: Tabs on precut hull p
Posted by John Foster on Sep 15, 2005
So that`s how you do it??!!! I thought you had John H and a bunch of elves working day and nite with coping saws!!! Did you retrain the elves? Just a note: Watersdancing kits have those tabs, sand them off; but they also have a square tab that is to be marked on the panel then sanded off. They are used to locate the bulkheads. I`d rather just measure though. To each his own.
In Response to: Re: Tabs on precut hull p by CLC on Sep 15, 2005
