Re: Wet sanding cleanup?
Posted by CLC on Sep 23, 2005
Denatured alcohol works. Don't fret too much; the very thin, dry white streaks left after wetsanding seem to disappear under varnish. The white streaks are just ground-up varnish that goes clear when the next coat is rolled on. Just make sure the surface is completely dry.
In Response to: Wet sanding cleanup? by raul on Sep 23, 2005
- Re: Wet sanding cleanup? by Steve Miller on Sep 26, 2005
