Re: Wet sanding cleanup?
Posted by Steve Miller on Sep 26, 2005
Easy way? What have you tried? I wipe the boat off with paper towels to get the bulk of the gunk off then use rags and water to wash it off. Change water and rinse out the rag often. No harder than washing a car. Be sure to dry it off with more paper towels when washed. If you can get the yak outside then hose it off, towel dry.
In Response to: Re: Wet sanding cleanup? by CLC on Sep 23, 2005
