Re: Wherry oarlock risers
Posted by CLC on Sep 30, 2005
Just make the risers higher. Making them longer will yield the stiffness needed as they get higher.
The original Thames Wherries on which the Annapolis Wherry is based had a similar problem, which they solved with tall and distinctively flared oarlocks. I don't think the Annapolis Wherry's risers need to be that tall, but it gives you the idea.
In Response to: Wherry oarlock risers by jimO on Sep 30, 2005
- Re: Wherry oarlock risers by jimO on Sep 30, 2005
- Re: Wherry oarlock risers by Howard on Sep 30, 2005
