Re: Outgasing after 1st c
Posted by Howard on Oct 2, 2005
once you have one coat of epoxy on...you should be immune to outgassing....i would still try suggest shooting for relatively stable or decreasing temperature for the second broad coat. there may be pinholes that are still open. after the second coat...i would probably not care.
hs
In Response to: Outgasing after 1st coat? by Mulepilot on Oct 2, 2005
17 days
for Discount Code Savings!
Ranging from $30 - $250
