Re: Stupid sanding questi
Posted by Mac on Oct 4, 2005
If you do get a drip - HERE I AM! Try scraping it off with a carbide scraper before sanding. Get it while its green or only semi-cured. I also hate to sand when not necessary - and I use cabinet scrapers to smooth epoxy prior to varnishing. I swear 3M's stock has bottomed-out since I switched to scraping.
You're sure on the right quest young grasshopper.
Best...
In Response to: Re: Stupid sanding questi by David Howie on Oct 4, 2005
- Last coat with a cloth? by Mike D on Oct 4, 2005
Sanding epoxy? by Mulepilot on Oct 4, 2005
- Re: Sanding epoxy? by Steve Miller on Oct 4, 2005
- Re: Sanding epoxy? by kurt freewald on Oct 5, 2005
- Ah, Wet Sanding by Mac on Oct 5, 2005
