Re: wet sanding varnish
Posted by George K on Oct 16, 2005
Jon,
You never said what grit sandpaper you were using. If you're using 400 wet or dry paper (wet, of course) and hand sanding (i.e. using your hand and not a sanding block)you shouldn't be taking off all the varnish. I use Epifanes High Gloss, seven coats top and bottom, wet sand in between. Builds up a nice finish.
In Response to: Re: wet sanding varnish by Dave on Oct 16, 2005
12 days
for Discount Code Savings!
Ranging from $30 - $250
