Re: wet sanding varnish
Posted by Doug Judd on Oct 17, 2005
I used the same basic process as Steve. Knock of the big runs and then 400 wet sanding until everything is dull. It doesn't take much pressure or effort.
I used four coats of Captains on the hull and three on the deck. This spring, I washed everything down with lacquer thinner, wet sanded again with 400 grit to remove last season's scratches, and laid on a single coat of varnish. Looked good as new.
In Response to: Re: wet sanding varnish by Steve Miller on Oct 17, 2005
12 days
for Discount Code Savings!
Ranging from $30 - $250
