Re: wet sanding varnish
Posted by Steve Miller on Oct 17, 2005
Sure. It will dull the gloss on the varnish just fine and take a bit more work than 400. I use 400 since I have it around and it seems a good compromise between a fine enough grit and speed of sanding.
In Response to: Re: wet sanding varnish by John Foster on Oct 17, 2005
11 days
for Discount Code Savings!
Ranging from $30 - $250
